Electric Cooling Fan on Air Conditioning
Dave C.
Any help welcomed, I have a broken cooling fan that is in front of the radiator on a system that has air conditioning (double radiator). Any suggestions for a replacement? Z3 2.2ltr 2001.
Althulas
Banburyshire
M Roadster
Dave C.
The motor has collapsed. It seems a couple of the glued magnets around the outside of the shaft windings broke away, probably a bearing failure.
Looks as though the motor seized. Not uncommon on forward facing A/C fans.
Dave C.
Yes, and being mainly an air con fan it doesn't run that much in the UK, that isn'ta help!
