Resource icon
Poor throttle response
Ken Nugent
North Yorkshire
Ken Nugent submitted a new resource:
Poor throttle response - Intermittent throttle response
Hi you experts
Starts first time no problem, when driving it steady in 4th or 5th gear, just over 2000 rpm suddenly the exhaust note disappears and the engine revs drop very slightly, press throttle hard and away it goes and its ok. driving it at a steady speed in traffic it comes back again but you can accelerate through it. If you floor it through 1sr, 2nd, 3rd & 4th it does'nt seem to miss a beat. There are no lights on the dash board, its done 60,000 miles. To me it feels as though...
Read more about this resource...
Ian&Sue
North Yorkshire
1.9 Z3
Ken Nugent
North Yorkshire
Hi
Many thanks for the info, we think we have got it sorted, it was an exhaust camshaft sensor but after saying this it was intermittent so we will have to wait and see. Linda is off this week so we will test it tomorrow. fingers crossed
Ken
137699
Hampshire
M Coupe 3.2 S50
I had a similar issue on my Z - which was down to lambda sensor failing.
Ken Nugent
North Yorkshire
Hi
Thanks for your suggestion however yesterday it pulled up a couple of fault codes one of which was exhaust camshaft position sensor. We have changed this, taken it out for a good run today hasnt missed a beat touch wood
Manyt thanks Ken
Always first port of call is to scan for codes as you found out, often points you in the right direction for a fix.
