Roof leak
I rarely use the car in the wet but I was booked in at a car meet last weekend and the heavens really did open. Rain came in on both sides at the top corners of the side windows/A pillars.
I am right in thinking something called Gummi Phlege swells the rubbers back up giving a better seal? Is it a cream? Appreciate any advice.
Cheers
Grumps.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Allan brought me this last week, I don’t know if it will help you 🌞
z3ddie
Also need to clean and plugged the drain holes with silicone - plenty of Youtube videos on it and on here in the knowledge base
ktnez99
West Midlands
Z3 2.8L
You may find that a liberal dollop of liquid rubber will be the only solution.
Along the top of the windscreen in the rubber is a channel amd in the corner, where I point in this picture, is a tiny hole.
Make sure that's not blocked.
Water should drain down through that hole and rin down the side of the a.pillar nside the rubber and exit here where I point with the screw driver.
It's a flap in the rubber. Open the door wide and get your finger in under the flap to make sure it's clear.
At the top of the a pillar is that rubber stopper. Take that out and male sure it's clean. Vaseline or gummipflege. Put it back in but don't gunk it up with silicon or glue or anything. You'll see a groove in the stopper water is supposed to run through the hole (top picture) down past the stopper in that groove and then down inside the rubber to exit by then screwdriver.
Make sure all the door rubbers are nice and clean too especially where the windows touch.
bertiejaffa
Manchester
Z3M
Trouble is, he has a Z4, the photo is just for confusion 😂
Z3 project
Vaseline will also revive rubbers too
Vaseline will eat rubber. Petroleum melts rubber.
Any silicone-based stuff (Gummi Pflege is silicone based) will clean and 'nourish' dried rubber and won't damage it. I use Autoglym rubber and vinyl care stuff. Spray it on a rag and wipe.
SV8Predator
Z4 E89 2.0 Atacama Yellow / Z3 3.0 Topaz Blue
It's a rubber conditioner. It doesn't "swell" the rubber, but keeps it supple. It won't stop leaks for you, you'll have to diagnose the leak problem, ie, exactly where the water is coming in, and then sort it.
brilie
doncaster
2.8 roadster
Try pushing strimmer cable down the hole at the top of the pillar to make sure it’s clear.
@Grumps you need to go back to the sales team and wave the warranty at them mate. 🎣:whistle:=))=))
Cheers Bri, I shall give that a go before I start exploring further 👍
Appreciate it, i did that when I had a Z3 and it used to leak, I now have a Z4 😂
Guinn
Texas
Mine leaks a little when it rains, and I found it's due mostly to the driver window not closing all the way to the top. It lacks about 1/8th in. (.3 cm) closing all the way.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
My latest Z roof leeks at the joints where the roof bends when opening and shutting. Am toldit spent 12 years in the hot area of France with roof down, will Gummi Pflege help in these areas to stop water running in through the grove where it bends ?. Advice appreciated Geoff
ChrisD
Evesham
M44
The rubber seals will definitely benefit from the application of a rubber care product. Will it stop your leaks? Come back and let us know!
