Throttle Cable
Allannorman
Recently bought a z3 and the cable is sticking.
its the 2.0l inline 6 and it seems to be that i cant find the right part anywhere online!
Any ideas if any other cables from other BMW cars will fit?
Cheers
roadvoyager1
Shotley Bridge
2.8ltr
Best place to find parts is http://www.realoem.com/bmw/enUS/select. Type your VIN number in as per instructions and it will take you to parts for your car, well normally. Had a quick look myself by guessing the production month of your car but failed to find the cable, so you may have to dig around a bit. There is also a cross reference function that, having found the part number, will list the models that the part was fitted too.
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Roadster
When I got my 1.9 4cyl, I had the same thing with the throttle cable sticking.
I disconnected it from the engine, held it as high as possible and dripped 3 in 1 oil down the cable. Worked it down by moving the pedal and after a while it freed off. That was 3 months ago, and it’s still working ok with no problems. :)
Allannorman
Brilliant, thanks for the link, and if all else fails i might have to give the oil trick a go, ive done it with some older motorbikes, but never on a car
Dino D
Kent
2.8 Manual
I last bought one from Bmw For about £30.
Massive difference, we’ll with it.
Been through 2 in the last 6yrs as they seize up so in the second one inoiled before fitting just to se if stays smooth for longer.
Allannorman
yeah just ordered it, unfortunatly realoem didnt have it in stock, ive found another site that has though, and yeah, around £30 mark, so not too bad
Give it a good lube before fitting it then Allan. Profitable day mate!:)
Allannorman
Well finaly got the cable, came from germany so bit of a wait to get it, lubed up pre install, and its made such a difference its unreal!
Cheers for all the help finding the right part
Nickyboy
Cheers
2.0 straight 6.
Got mine from BMW dealer £56 with clips which I didn’t need to use, but they didn’t supply the grommet that goes on the pedal, mine fell apart. The ball end on the cable just needs pushing out the back of the housing, took me a while to work it out. I’m only putting this on now to help anyone else replacing cable.
