Trouble finding correct wheel speed sensor.
Kwinterowd
I went to change my LR wheel speed sensor and found the alignment fins in the connector is different than the OEM. 2002 2.5 Roadster.
Did you match the part numbers when buying the part?
Find the part you are looking to replace on RealOEM.com and then use that part number to buy the part, ensuring it is always the correct one.
Here is a guide to help:
