Gear knob doesn’t centre
rmoconnor41
Hi
perhaps you can help with some details of the issues the gearbox is having when the gear stick doesn’t centre.
when driving I have to guide the gear stick between gears. Although I have almost mastered this it does result in the occasional wrong gear getting selected.
I believe it relates to pins but that is as far as my knowledge extends
Thanks
  • Agree
Reactions: Lee
DrWong
3.0i
Yep, worn detent pins in the gearbox. Fairly straightforward to replace the pins themselves, but the gearbox has to be removed first
@Lee is well versed on this repair. Check out some of Zshed HQ rebuild threads.
Pingu
It's not the detent pins - the role of the detent pins is keep the car in gear.
It is the sintered steel pistons and bushes that have become too tight for the springs.
There was a very good page on t'web (https://webspace.ringling.edu/~dplassma/bmw_diy/shift_pins/shift_pins.html), but it seems to have disappeared.
Recently, someone did a thread about this and the cost of some of the parts have gone up
Tony's on the money, the 5th gear indent pin liner breaks down causing the pin to stick inside. Normally with this once warm the gearbox feels fine unless yours is really worn.
I've dragged this photo out the zedshed section. The two shown here are 5th and reverse.
Cheers Lee.
DomiMik
German Zeds
🇭🇷 》Croatian living in Germany《 🇩🇪
You can access the web page via wayback machine:
Pingu
Mike Fishwick
French Zeds
Daglan, France
An oil change to a synthetic 75-90 would be a good place to start, before ripping the gearbox apart.
New pins and bushes in mine courtesy of @Lee certainly cured mine, and if the box is out its worth a new clutch kit.
  • Agree
Reactions: Lee
