mmmm.just a thought....I certainly didn't think there was enough space
Well they failed me my MOT...Probably a wise decision, hard to tell from here. Would be interesting to see the state of the bits that are to be replaced, I for one haven't heard of the "push rods" being that bad before, not that I know everything. Just hope that things don't get worse as the dismantling goes on.
I can't understand why they used Allen bolts!![]()
These are the bolts that I removed. The heads had so much rust on that I couldn't tell what Allen key size they were. However the threads were quite reasonable and so once I'd got the bit properly engaged in the recess, they came out easily.
They wanted to see if we could take a joke..........................FrankieI can't understand why they used Allen bolts!
I wouldn't give up, if its a generally good car better to fix it than buy another with god knows what problems. Of course only you can determine that.I'm still not sure what to do. Whether to just cast the car loose. Then look for a cleaner car. I don't have the means to do the job myself. So will always have to go to a garage, where the Labour cost is a burden.
Too right Niall. Better the devil you know. . . . . . .I wouldn't give up, if its a generally good car better to fix it than buy another with god knows what problems. Of course only you can determine that.![]()
Good on you Paul. Make sure your garage reassemble everything with plenty of suitable anti seize compound...Made the decision to complete the repair, parts ordered.
Sorry no pics as Zed in a garage.
Never say never I say, the car is likely to last another 20 years, better to make it easier in futureGood on you Paul. Make sure your garage reassemble everything with plenty of suitable anti seize compound...
,,,not that you will need to take it apart again!
If you know I mean.
Good news Paul.After my panic last week, work done and passed MOT yesterday. Only one advisory, suspension arm has slight play in a ball joint offside front lower.
So car taxed and ready to roll. Added bonus was much cheaper than expectedPhew
Happy Bunny
