Wheel size issue need some help pls
id101
I still struggle with understanding wheel fitment despite people trying to explaining it over and over, so ill ask.
I have a 2002 z3 3.0 which been lowered bilstein/eibach
Some wheels are available sized
17x8 front et20 offset
17x9 rear et20 offset
Am I going to have trouble with these?
Yes you may the offset on both axles could leave wheels out too far .
I run style 18 on my 2.8 pre face-lift
Running rear wheel on front
17x 8.5 et41 ( factory offset)
And 5 series rear style 18
17x 9 et22 only just fits wheel sticks out over wheel arch but run 245 still on rear to keep tyre under arch.
You would really need to test fit to see how they look.
3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
www.willtheyfit.com is your friend to help understand the difference offsets make.
You can put in your existing wheel criteria against another and it will show the differences they will make in relative terms. It can't tell you about any potential rubbing on arches, though.
id101
Yeah this is the problem, id need to buy tyres for them as well so a risky purchase if they rub etc.
Rudyrov
Phoenix, AZ
2.8 L Roadster
Speaking of wheel size, has anybody experimented with the 16 inch wheel in a 60 series instead of the 50 profile?
Looking to bring down the RPM at highway speeds and get better mileage.
Thanks!
Thanks!
Yep. I've got 195/65*16 on the front and 205/65*16 on the back. Front wheels are 6.5" rears are 7"
IIRC the speedo error is around 6%. But it was about 6% wrong anyway so now its pretty much spot on.
I know it's not a standard z3 body but the transmission is standard z3. Means at motorway speed the car wouldn't be reving quite as high but it's hardly noticeable and I still find myself looking for the missing 6th gear. You'd need to go crazy big to make any real difference.
Go to willtheyfit.com to experiment with various sizes to see what % difference it makes.
Go to the website willtheyfit.com willtheyfit.com where you can key in different sizes and you'll see a diagram of new over old and see how the height, width and offset affect things.
Hi had a look on will they fit this would be your differences between stock staggered 17
7.5 and 8.5 et41 225/45 fr 245/40 r
Threar you might just get away with you would be 2.4 mm further out than my rear its the front my 8.5 et41 pushes wheel out 12.7mm your et20 would push wheel out 27.4mm
This is a picture of mine and @Scooblitz Zed Stevie and i have similar setup both 8.5 et41 fr 9j rear mine et 22 Stevie et26
Still think rear should just get away with front rekon wheel stick out a chunk.
Stephen
Rudyrov
Phoenix, AZ
2.8 L Roadster
Thanks for the information, I will keep it in mind next time I need tires!
Rudy
Scooblitz
Glasgow, Scotland
Yes. In a word.
The front is usually the difficulty. 8.5” et41 which is equivalent to 8” et 35 is about the maximum you can run without some sort of modification or compromise.
17x8 et 20 with a 225 tyre is going to push well beyond the front arch. Skinny tyres, shims or camber plates will allow them to tuck under but this will require money on new suspension and sounds like you have already got new springs on.
The rear will be a touch too much imho. ET20 will be pushing the limits, especially if you are lowered.
What wheels do you have in mind?
id101
Yes. In a word.
Some bbs replicas one piece wheels. I like the prefer the dish on these rather than stepped most have.
