When am I allowed to fit a race clutch and diff Dino
Steady on, it’s only been four years since you got it back in shape...I’ve had a clutch kit on eBay watchlist for 2,5yrs...M50 manifold in the box for 2yrs...who knows 2019 might be the year it actually goes on the car...When am I allowed to fit a race clutch and diff Dino![]()
DIFF SWAP UPDATE 3.15 LSD to 3.38 LSD (TORSEN)
Well what a fun day!
Top down all the way from Kent to Basingstoke at the crack of dawn.
Lovely breakfast and then some whacky races around the Basingburgring with the VAG fan boys, (terrible dieseasel lovers to make things worse, had us choking in the Z3 with their fumes. Not naming any names but @Rally knows what I mean)
The Z returns after 4,5 yrs:
Car raised and the work begins (that work includes swearing, getting covered in amazing amounts of rust, having a laugh and a bit of pain - it’s takes some seriously clever manoeuvring to get the diff out when you don’t have a saggy subframe!):
Extension on extension on extension on extension...you get the idea!:
Gaz thinking ‘how the hell have I ended up back under this old shed?!’:
The now infamous Zedshed footwear standards have been maintained over the years however there is a new sock code to adhere too now
Okay now some technical stuff.
2.2 3.38 diff next to 2.8 3.15 diff (both confirmed to be torsen items)
Spot the difference?
View attachment 116337 View attachment 116339 View attachment 116341 View attachment 116343
Nope, neither did we, luckily BMW put a helpful little sticker on that is just about there after 20 years!
Turns out that a 2.2 diff is direct fit with the MK1 2.8 - no changing of propshafts or drive shafts or flanges (@Lee gave a detailed explanation of what exactly went on and @Rally took even more detailed notes so if you need more tech specs on this point @Rally is the man to ask)
In between work we did squeeze in some cultural education and Lee kindly let us have a play with a proper drill from the 50’s. Why don’t they make stuff like this anymore?
@Rally and I went to the same school of engineering - when in doubt hammer it (turns out to be safer than using a grinding too)
Not too much appreciation for my love of cable ties from the proper engineers but some of the VAG crew knew the benefits. So much so we are apparently getting Carol Vordeman to do count of how many ties we have on each car
A good example: This tie reinforced exhaust mount looks as good as I ‘engineered’ it 4yrs ago
The pile of bits that that came off kept growing...
Comment on the BC and poly bushes after 4yrs - the springs are rusty and this year the coating has come off them but the shocks are still good and leak free which is more than I can say for other coil overs I’ve had, still very happy with the BC kit and will give the springs some attention.
The poly bushes are as good as the day they went in and despite worries / internet talk that they would cause the diff mount to fail that has not been the case I’m pleased to report.
The car is getting very crusty under there so needs some love under the bodywork this winter...
So mid afternoon and all back together again.
A couple of, ahem, test drives around the Basingburgring by Lee and Gaz to confirm all is well.... View attachment 116345
So the big question- what does it drive like???
Initial impression feels like it had a little turbo bolted on. It was just more urgent everywhere.
1st is still very usable and changing to 2nd will be interesting in the wet at full bore. 2nd to 3rd is superb, just pulls and pulls.
2nd is now particularly good at skids - the LSD part of this is confirmed as being healthy (although some wet weather testing will be needed just to be extra sure)
I had to head back onto to busy M3/M25 to Kent so got to really test out 5th in the usual 70mph > 5mph > 70 >40> 70 type driving that is the British motorway on a weekend.
What can I say - 5th is epic - I no longer go for 4th when spotting a gap, just plant it in 5th and it goes at any rev.
It feel like it is a 4.5th gear now.
Cruising revs are higher and my calcs say it will do just over 130 before entering the red. So 10mph down - not that I’ll miss it given we don’t have any autobahn
Closer to home I got into familiar A roads and lanes and got use the gears more. The difference became very apparent on familiar roads where I could really compare. The easiest way to explain it is like having a small turbo- no lag and just more torque. If you’ve owned a VTEC you’ll recognise this analagy - it now just falls into VTEC after each gearchange, even if you didn’t redline it so it’s in its ide powerband more of the time.
Although the gears are shorter I can actually rev out a gear more as instead of taking 2nd, 3rd will do (which has always been a good year on the 2.8 but now even better). 4th is great for flowing A road work now, lovely torque and pulls strongly a bit like 3rd used to be..
I then tried ‘lugging’ it in 5th. The 2.8 party piece has always been how tractable it is even in 5th. Well now it’s even better and the shorter gear, funnily enough, make for a more relaxing drive as I can leave it in 5th and still have plenty of poke on a nice A road. It’s pulls cleanly from under 20mph and in no time up to 60 all in 5th. The only car I’ve driven that pulls like this is has 8 cylinders and 4.4l at its disposal. The little Z really feels more brawny now.
So initial impressions - love it more that I thought I would. I’ve hung on to my old diff in case I didn’t like this but I don’t see this 3.38 coming out of this car (unless a turbo ended up under the bonnet!).
If I did a lot of motorway work I’d want a 6th gear (and if we find a box that fits and is not off a unicorn M3 EVO it could well happen - currently the knowledge is that only the M3 EVO 6sp will fit with shortened prop shaft. However, maybe, just maybe there is another ZF box in the BMW parts bin that will work and is more freely available than a M3 box, here’s hoping). With a 6th gear it would be better than BMW intended and what they really should have done in the beginning...
For the way I use this car (for pleasure not commuting big miles) this mod is just perfect and I’m looking forward to re-learning driving it along familiar roads as the gear shift points have all changed!
Oh and a side effect of this is a positive change in exhaust note - it’s just sounds ‘more’ now given the revs it sits at / way the power is being delivered. After the remap, the track day and now this diff the car is sounding better than ever (apart from a rattle which is looking like the cat and not a bracket- on the bright side it means that the sports cat I’ve wanted for years just has to be done. Is, along with a sneaky bypass valve - after hearing what it sound la like without a backbox on it just has to be done).
Reflecting back on the car with Gaz and Lee looking at all the changes it’s quite something that a car I was thinking of breaking 5yes ago was brought back to life in the Zedshed and has blossomed - just so much fun for so little £ cost and endless fun tweaking (the frustrations get forgotten!)
it’s a hard to beat formula and one of the many reasons for me anyway, a Z3 is a no brainer keeper!
Final shot of the day in its national habitat - it’s the second time in month I’ve filled up twice in a day
Thanks again to @Lee @GazHyde @Rally for the hard graft and fun and to @pgunter and @Oldguysrule rule for coffee and moral support
Who knew that rolling around under a Z3 fighting with rust inaccessible bolts is actually fun with the right company (and tools and experienced supervisors!)
with some esteemed company, the car needs to be in fine mechanical shape.
(as I’m running a raised limiter the risk of oil pump nut increases as proven by a certain @Lee so I said I’d get the limited dropped but had a few *ahem* moments when it strayed past the end of the rev counter when testing out some old rubber...
so a cheap refurb is needed- which I want to do anyway to ensure they all straight and crack free - they worked out £200 for the set so still great value even with the refurb):
You must try these pads- I doubt you’ll be able to kill them, amazing stopping power on what are rather weedy stock discs and calipersAwesome upgrades mate
Amazing write up mate enjoyed reading that. I'm hoping our trip to the ring goes ahead next month but I'm not holding my breath. We've decided our plan B is to book a track day in the UK. Really looking forward to seeing how our cars feel on the limit, they're so similar now.
Just need to get your lightweight flywheel and race clutch in
P.S in the new handbrake picture the handbrake mech has come out the groove on the shoe.
can’t wait to get on track and see how it goes!
re the clutch -been digging and found a post on PH about a guy who fitted the 6 sp out of a 330i:
https://www.pistonheads.com/gassing/topic.asp?t=1247633
hi, i have just fitted a 6 speed out of a 330iE46 into my 328i E36. This is the same gearbox as the 320d and 330d, however the diesel versions have different gear ratios and the engines sit 10 degrees more upright. This would cause issues when fitting to a petrol model, new engie mounts would be needed.
Anyway back to the 330i box, the input shaft was alot shorter than the original box as the spigot bearing is mounted in the fly wheel, so in answer to your question, you will need to change the flywheel for the correct one to suit the box.
What i done though was looked on ebay and found a fly wheel and clutch from a 320d for under £80 , these are alot more readily available than the 330i ones, so was not a great expense. The only mod required to fit the diesel flywheel was the guide tube for the release bearing needed 10 mm taking off. The set back of using a diesel fly wheel is that it is slightly heavier, but you are unlikely to notice this when driving. You will need to take 4 inches off the propshaft and also fabricate a new gearbox support bracket. the original slave cylinder works however i need to put two washers on the studs before fitting it to the box as it was too close to the release arm.
in hinds sight E46 M3 box is probably alot easier also if it is going on a 328i i dont think you need to change the clutch and fly wheel as they are the same. This is 328 only with ZF box.
So looks like a M3 box is not needed but a 330i clutch/fly wheel is. Must be some light weight options for those by now...
Re the handbrake, I don’t think that pic was of the finished article-no horrible noises so sounds like it’s all in place properly (here hoping!).
I’ll need to upgrade the rear pads so will shop of the disc and check. What pads do you run on the rear? EBC yellow were crumbling on the rear after Lydden so think they could with a as bit of cooling as well..
That's a cracking find with the gearbox. All mods I can do myself now have a machine shop under my control. I'm not that fussed with a 6th gear but if the parts are cheap enough we could sit down and price it all up.
I run stock brembo rear pads, I get so much stopping up front I can late brake most corners. I've never had any issues with the rears even over the whole weekend on the ring where most stopping is done from above 100.
